Community Member
FWSM 4.0 and CSM 3.2.2 sp2 interface renaming
Hi I encounter and erro when I try to rename an interface of a context of FWSM 4.0 in transparent mode, through CSM 3.2.2 sp2: how to in CSM ?
I don't want to use CLI and import the context again.
thank you
Bronze
Re: FWSM 4.0 and CSM 3.2.2 sp2 interface renaming
In multiple context mode, to rename a context without changing the configuration is not supported.
You can save the configuration as a firewall configuration, but you need to copy the entire configuration to a new context name and delete the old context configuration.
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809bfce4.shtml#intro
Community Member
Hi, I don't need to change the context name but only the 2 vlan interface names of a bridge (couple of 2 interfaces) of one of the FWSM contexts.
Now the CSM is 3.3 version.
thanks
174
