FWSM and SNMP ARP mibs
Hello
I have two FWSM cards in two 6513 switches with failover activated.
Connected to the switches are several servers connected to the different interfaces of the firewall. One of them is one HPOV ( openview ) which needs the ARP table of the FWSM to reach and explore the whole net to begin to monitorize the network.
My problem is I cannot get the ARP table from the firewall, so, I cannot discover more devices, i'm able to SNMP them by editing the SNMP poller in the OVO configuration file, but even the network devices appears, it cannot reach by discover job.
I paste my sh ver here .
FWSM -1# sh ver
FWSM Firewall Version 3.2(1)
Device Manager Version 5.2(1)F
Compiled on Thu 07-Jun-07 20:16 by dalecki
FWSM-1 up 7 days 13 hours
failover cluster up 1 year 94 days
Hardware: WS-SVC-FWM-1, 1024 MB RAM, CPU Pentium III 1000 MHz
Flash STI Flash 7.2.0 @ 0xc321, 20MB
0: Int: Not licensed : irq 5
1: Int: Not licensed : irq 7
2: Int: Not licensed : irq 11
The Running Activation Key is not set, using default settings:
Licensed features for this platform:
Maximum Interfaces : 256
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
BGP Stub : Disabled
VPN Peers : Unlimited
Serial Number: SAD101804FV
Running Activation Key: 0x00000000 0x00000000 0x00000000 0x00000000
Configuration last modified by enable_1 at 13:59:35.590 CET Mon Nov 3 2008
I think 3.2 version cannot retrieve the MIB for ARP, and I have finded that version 4.01 does. But I was unable to find any kind of upgrading notes here, and we have the monitoring of server farms proyect sttoped for this problem.
Does anybody have had this problem?
How did you solve this?
Thanks!
  • Other Security Subjects
1 ACCEPTED SOLUTION
Re: FWSM and SNMP ARP mibs
Angel,
You are correct, the "ARP table entries (IP-MIB)" MIB was introduced in 4.0(1) and you have to upgrade to 4.0 code to get pull the ARP Table through SNMP MIB.
And below is the document that has information on upgrading FWSM.
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/configuration/guide/swcnfg_f.html#wp1052902
Arul
*Pls rate if it helps*
Angel,
Arul
So Arul does that mean that the CiscoWorks LMS Campus Manager will support the FWSM for UserTracking anytime soon?
Farrukh
436
