FWSM and VLANS withing MSFC
I have FWSM configured in a 6500 chassis. The MSFC is logically installed before the FWSM which means the firewall is the one connected to the internet. I have only one VLAN shared between the MSFC and the FWSM. The problem is that the FWSM can reach anywhere except the VLANs configured on the MSFC (other than the shared VLAN). I have static routes on my FWSM pointing to the MSFC to reach other VLANs on the MSFC. NAT is also there. Can anyone give me any clue? Is this related to SVI? Do I need SVI on my configurations?
Re: FWSM and VLANS withing MSFC
Anonymous
N/A
What Type of MSFC are you using? Also if you are using ping from the FWSM you may want to check out the ICMP command. If you show me your config on the FWSM and MSFC maybe I can see something for you.
95
