Community Member
FWSM-ASA-Remote tunnel
SMTP connectivity needs to be established between location 1 to 2
location 1
From FWSM to ASA the traffic goes fine
but from ASA to the location 2 the traffic from one specific segment is going other segment traffic fails...
Need clues....
location 2 :
managed by a PIX 506 where the tunel is open and looks fine
Re: FWSM-ASA-Remote tunnel
routing ok end-to-end?
ACLs permit traffic?
NAT (or no-NAT) ok?
allow ICMP and try that.
if possible get a Cisco router at each end, "debug ip icmp" and ping between them.
telnet port 25 to mail server - if thah works but mail does nto flow, it could be "fixup protocol smtp" blocking esmtp commands.
Community Member
does the fixup protocol smtp 25 blocks the esmtp
does esmtp works on any random port?
esmtp is Extended SMTP, which uses more than the few basic commands of SMTP. "fixup protocol smtp" limits the allowed smtp commands to a few essential ones, blocking the unneccessary and less secure ones. Unfortunately it seems to break esmtp too.
If you mail server is on a different port you can do "fixup protocol smtp [new_port]" to apply the fixup to that port.
