FWSM failover question
I config FWSM failover. But why it diaplay "Interface outside (0.0.0.0)" when I enter "sh failover" command ?
thanks!
FWSM# sh failover
Failover On
Failover unit Secondary
Failover LAN Interface FAILOVER Vlan 910
Unit Poll frequency 1 seconds
Interface Poll frequency 15 seconds
Interface Policy 1
Monitored Interfaces 2 of 250 maximum
Last Failover at: 07:26:17 Dec 12 2005
This host: Secondary - Standby
Active time: 0 (sec)
Interface outside (0.0.0.0): Normal (Waiting)
Interface inside (0.0.0.0): Normal (Waiting)
Other host: Primary - Active
Active time: 1886 (sec)
Interface outside (10.1.255.3): Normal (Waiting)
Interface inside (98.1.1.3): Normal (Waiting)
Re: FWSM failover question
Can you revert whether you have configured the standby FWSM module also have u checked up for the ios codes in both the modules ?
is it possible to check whether the standby module is deteced and ready (on state)?
you can check out with show monitor-interface command also to verify the active/standby itnerface status..
for more info on the same do refer this link ..
http://www.cisco.com/en/US/partner/products/hw/switches/ps708/products_module_configuration_guide_chapter09186a00802010c0.html#wp1076500
regds
I got it. I need config "ip address ... standby"
thanks!
129
