Community Member
FWSM logging problem
I have the following items in my logging configuration for a transparent context on a FWSM:
logging buffered warnings
logging trap warnings
I have an inbound acl with the following as the last ACE:
access-list ingress extended deny ip any any log errors
However, I am not getting 106100 messages logged to either the log buffer or syslog server (although I am seeing an incrementing hit count on the ACE).
BTW, the syslog server configuration and facility configuration are correct ... I previously had the messages for build/tear down udp and tcp connections redefined to level 3, and it worked fine. Any ideas why the 106100 messages aren't being generated? Thanks.
1 REPLY
Community Member
Re: FWSM logging problem
In case anyone is interested, this is a known problem w/3.1(1) (and other) FWSM code. The bug id is CSCsd80511, and it's fixed in 3.1(3).
132
