11-11-2003 11:39 PM - edited 03-09-2019 05:29 AM
Anyone known if the fwsm ver 1.1(3) is supporting bidirevtional nat or outside nat as pix does ?
Thank for any help
Best Regards
Fabio Bellini
Solved! Go to Solution.
11-12-2003 06:04 AM
Fabio,
Nope, no bidirectional or outside NAT support in FWSM 1.1(3) code. We are adding this to the 2.1 code which should be out around the first of the year. The 1.1 code in the FWSM mirrors PIX 6.0 code (with the exception of OSPF). The 2.1 FWSM code should mirror the PIX 6.3 code. So, anything added after 6.0 in the PIX is not going to be supported until FWSM 2.1. Hope this helps.
Scott
11-12-2003 06:04 AM
Fabio,
Scott
12-01-2003 10:22 AM
Do you know where I can find some configuration documentation for the FWSM ?
