FWSM Replacement
Hi all
I have 2 FWSM configured in active/active failover in multiple mode.The FWSM in the Primary switch is crashed.i need to replace this with new one .upgraded the IOS and license as that of secondary one.Please anybody tell me what r the required configuration to make this new FWSM again as active.
Re: FWSM Replacement
When the FWSM
is configured with failover lan unit primary
it becomes a primary FWSM
The preempt command in the failover
group configurations cause the failover groups to become active on their designated unit after the configurations have been synchronized and the preempt delay has passed
each firewall must have a different keyword (primary or secondary) in its configuration to differentiate its
firewall identity. Therefore, you must add this command to the primary and
secondary firewalls independently
(FWSM only) Allow the primary FWSM to preempt the secondary:
Firewall(config)# failover preempt [delay]
Normally, the firewall that has the active role keeps it until it fails or until you
manually intervene. Beginning with FWSM 3.2(1), you can configure the primary
FWSM to preempt its peer for control over the active role. With the failover preempt
command, as soon as the primary FWSM boots up, it can preempt the secondary unit
and take over the active role. By default, the primary unit preempts immediately.
You can set a delay (1 to 1200 seconds) to force the primary unit to wait before
assuming the active role
hope this helpful
Thanks Marwanshawi for quick response.My doubt is If i configure only the failover commands in the new fwsm (primary)whether it will synchronise the all configuration(config of all context and system)of secondary fwsm with new one? or we need to configure all the configuration on new fwsm?
Thanks in advance
632
