Generate RSA keys with ASDM 6.1
I have been looking in ASDM 6.1 for a link to generate the key pair for my ASA5510 and can't seem to find it anywhere. Can someone maybe shed some light on which section I should be looking in.
Re: Generate RSA keys with ASDM 6.1
follow this on the ASDM interface ...
Configuration > Device Management > Certificate Management > Identity Certificates .. then Add
Under Add a new Identity certificate click New in order to add a default key pair if one does not exists.
Then, click Generate Now.
Thanks. It worked great. Have to find where everything is here.
you are welcome.
please rate if it really helped you. :)
It did and I am trying to find where I can put in my Trustpoint information in this version of the ASDM as I can't find the Trustpoint in the navigation pane.
here is the path.
Configuration > Properties > Certificate > Trustpoint > Configuration
1959
