global (outside) IP same as outside interface IP?
Is it possible somehow to NAT to the outside interface IP of the PIX firewall? I've tried setting global (outside) 1 IP like outside interface, but I get this error message: "Start and end addresses overlap with outside interface address"
My customer only have 1 IP-address available, so my PIX config really depends on this issue...
Thanks in advance,
Thomas Vådahl
Network Admin
ADCom Data
Re: global (outside) IP same as outside interface IP?
I forgot to mention that I've tried "global (outside) 1 interface". The error message I get is "Type help or ? for a list of commands".
I have a pile of Cisco PIX 501 sw 6.1(3).
./thomas
Ensure you have the following lines in, before you attempt the global command.
ip address outside 192.150.49.1 -> Gives the outside interface an address
nat (inside) 1 0 0 -> This line allows all addresses on the inside, or whatever you want to name it, to NAT (when allowed by an access-list).
global (outside) 1 interface -> This tells the Firewall to NAT using only the outside interface address.
Hope this helps :-)
Yes - it works now.
-Thomas
257
