GRE between Cisco router 2600 and AT-AR 390
Is it possible to tunnel Cisco router 2600 and router telesyn AT-AR 390, how can we configure. HOw secure about tunneling with GRE
1 REPLY
Silver
Re: GRE between Cisco router 2600 and AT-AR 390
As long as the Telesyn router supports open standard IPSEC it should be possible since Cisco’s code follows all the standards. The Cisco config samples are here: http://www.cisco.com/pcgi-bin/Support/PSP/psp_view.pl?p=Internetworking:IPSec but you’ll have to check with Telesyn for their configs.
117
