Community Member
GRE through an ipsec tunnel between a router and a concentrator
Can one create a GRE tunnel from an internal router, through a 3005/15 connected to either an ipsec router or hardware client, into another router at a remote site.
Router <---GRE---3005/15 <----IPSEC--->H/W client or IPSEC router ---GRE--->Router
This would allow for dynamic routing updates between central and remote sites. I know it can be done with two routers, but was wondering if the 3005/15 could handle it?
Billy
Community Member
Re: GRE through an ipsec tunnel between a router and a concentra
we have this:
GRE
-->IPsec------------------------------------>IPsec----------------------->GRE
router------------------------------------->VPN3005----------------->router
the GREoIPsec tunnel is used to manage the isdn bckup link with the hello protocol of OSPF and a floating static.
bye,
Graz
You could form a gre tunnel between routers behind a VPN 3000 and a router doing IPSec lan to lan.
244
