GRE tunnels with static and dynamic crypto maps possible ?
Dear all,
I have set up a VPN with IOS routers using GRE tunnels over IPSec. It is working fine so far. All my currently connected routers have static official internet IP addresses. Now I am trying to extend the configuration to support as well routers with dynamically assigned official addresses, but I can't get it running (phase 2 SA policy not acceptable).
I am trying "crypto dynamic-map" and the "crypto identity" commands for the dynamic IPSec tunnel. Within the GRE tunnel I have no "tunnel destination" command.
Is this possible to work ? If yes, what am I doing wrong ? Please have a look at the attached configuration fragment from my central site (my dial-in router is configured the same as my static routers):
crypto isakmp policy 100
encr 3des
group 2
crypto ipsec transform-set to_vpn esp-3des esp-sha-hmac
mode transport
crypto dynamic-map dial-in-router 1
set transform-set to_vpn
set identity myhome
match address Location1
crypto map mycryptomap 99 ipsec-isakmp
description VPN to Location99
set peer 99.99.99.99
match address Location99
crypto map mycryptomap 147 ipsec-isakmp
description VPN to Location147
set peer 147.147.147.147
match address Location147
crypto map mycryptomap 202 ipsec-isakmp
description VPN to Location202
set peer 202.202.202.202
match address Location202
crypto map mycryptomap 1000 ipsec-isakmp dynamic dial-in-router
crypto identity myhome
fqdn myhome.mycompany.com
interface Tunnel1
description Location1, dynamic remote IP address
bandwidth 512
ip address 10.227.1.1 255.255.255.252
ip accounting output-packets
ip mtu 1440
tunnel source Ethernet0 ! no tunnel destination ?!
interface Tunnel99
description Location99
bandwidth 512
ip address 10.227.99.1 255.255.255.252
ip mtu 1440
tunnel destination 99.99.99.99
interface Tunnel147
description Location147
bandwidth 512
ip address 10.227.147.1 255.255.255.252
ip mtu 1440
tunnel destination 147.147.147.147
interface Tunnel202
description Location202
bandwidth 512
ip address 10.227.202.1 255.255.255.252
ip mtu 1440
tunnel destination 202.202.202.202
interface Ethernet0
description to Internet
ip address 193.193.193.193 255.255.255.248
ip access-group 140 in
ip access-group 150 in
half-duplex
interface FastEthernet0
ip address 10.10.10.10 255.255.255.0
ip route 0.0.0.0 0.0.0.0 193.193.193.194
ip route 10.0.0.0 255.0.0.0 10.10.10.1
ip access-list extended Location1
permit gre host 193.193.193.193 any
ip access-list extended Location99
permit gre host 193.193.193.193 host 99.99.99.99
ip access-list extended Location147
permit gre host 193.193.193.193 host 147.147.147.147
ip access-list extended Location202
permit gre host 193.193.193.193 host 202.202.202.202
access-list 140 permit esp any host 193.193.193.193
access-list 140 permit udp any eq isakmp host 193.193.193.193 eq isakmp
access-list 140 permit icmp any host 193.193.193.193
access-list 140 permit gre any host 193.193.193.193 log
access-list 140 deny ip any any log
access-list 150 permit esp host 193.193.193.193 any
access-list 150 permit udp host 193.193.193.193 eq isakmp any eq isakmp
access-list 150 permit icmp host 193.193.193.193 any
access-list 150 permit gre host 193.193.193.193 any log
access-list 150 deny ip any any log
1 REPLY
Re: GRE tunnels with static and dynamic crypto maps possible ?
Dynamic Multipoint VPN (DMVPN) is what you want. It's a new feature in 12.2(13)T, explained here:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t13/ftgreips.htm
This'll make your hub router configuration much simpler, and your spokes can all be a very standard config.
455
