p21
Hairpinning issue with ASA 7.2(2)...
I'm trying to allow access from a remote office to a central office:
They're both connected to the inside interface.
I'm trying to get to a Print Server on 192.9.200.123 from 172.25.50.200. I thought it was a case of just enabling hairpinning. At the moment local users
can get out through the ASA but nothing remote can get back in. In the logs it's failing on 'nat (inside) 1 0.0.0.0 0.0.0.0'.
A little bit stumped at the minute... there's not much more configuration on the box than that below.
Some config:
same-security-traffic permit intra-interface
access-list inside-acl extended permit ip any any
access-list inside-acl extended permit icmp any any
global (inside) 1 interface
global (outside) 1 interface
static (inside,inside) 192.9.0.0 192.9.0.0 netmask 255.255.0.0
static (inside,inside) 172.25.0.0 172.25.0.0 netmask 255.255.0.0
access-group inside-acl in interface inside
access-group inside-acl in interface outside
route inside 192.9.0.0 255.255.0.0 172.25.50.1 1
route inside 172.25.0.0 255.255.0.0 172.25.50.1 1
Green
Re: Hairpinning issue with ASA 7.2(2)...
You should not need those statics since you have
nat (inside) 1 0 0
Give it a try without them.
Something may have changed with the ASA, but I remeber hearing that the PIX could not route traffic back out the same interface it came in.
222
