12-09-2002 03:29 AM - edited 03-09-2019 01:19 AM
I'm currently testing the Hardware client 3002 with a VPN 3030 concentrator. The hardware client is directly connected to DSL and is using PPPoE. NEM (Network extension Mode) and hardware client authentication is configured. Split tunnel is allowed; Only interesting traffic to HQ should be encrypted.
Opening a connection to the HQ and to the Internet works fine.
The problem is now to get access to the Internet while the VPN tunnel is down. This does not work. That means that Internet access is only possible when the VPN tunnel is established. Is it really a feature or a misconfiguration ? Software is uptodate.
Any Ideas ?
12-09-2002 10:57 AM
This is a feature and not a misconfiguration.
Arul
12-09-2002 11:25 AM
Not to mention the use of split tunneling is considered a security risk.
12-09-2002 11:15 PM
It's a pity. This makes not easier to troubleshoot this device for a standard user.
I know split tunneling might be a security issue. Nevertheless it is a strategic / business decision.
But it works perfect with the software client. I thought i can implement the same behavior with the hw client.
Thanks for help
Stefan
