HDS Storage Navigator (Java tcp 2000) fixup prot skinny
js.franklin
Using Storage Navigator (Java app on Port 2000) It wouldn't work until I turned off the skinny fixup. Client access across another vpn tunnel with fixup skinny on won't work. Question: When Tunneling all traffic (nonat) across ipsec vpn does the fixup still inspect all traffic through the tunnel?
Both firewalls are Pix 515 with 6.3(5)
bstremp
Level 2
Level 2
