help,how to setup my CSPM 2.3.3?
first,I use import the pix to generate the top diagram,then save it in *.xml file,then I run CSPM ,select the top import,after the import,I want to save,but it tells me:system consistency check failure.SAVE operation aborted
then I find 3 messages(2 errors,1 warning):
pixfirewall unassigned/invalid ip address for "enforcement service"
pixfirewall no policy distribution point assigned
pixfirewall no status specfied
another problem is how can I mail ids log to internet?when I choosde the "configurations notification",the email box can't be checked(is grey).
how can I do?and how should I do after save the top?
thanks
  • Other Security Subjects
Re: help,how to setup my CSPM 2.3.3?
The first issue is the result of either not defining the CSPM server in the topology or not assigning the CSPM server to the PIX as a policy distribution point.
There are a few steps to go through before you can configure the the SMTP notification. You will have to add the SMTP host to your topology and then add the SMTP service to the host before you can select it as the SMTP service to use for notifications. Here is a link that explains this procedure.
http://www.cisco.com/univercd/cc/td/doc/product/ismg/policy/ver23i/idsguide/ch09.htm
Hope this helps,
Marcus
but how to define the CSPM server in the topology or assigne the CSPM server to the PIX as a policy distribution point.
thank u very much
nobody knows it?
83
