04-10-2006 04:06 AM - edited 03-09-2019 02:33 PM
Hello all,
Does the presence of the crashinfo file below indicate that my PIX has experienced an error it could not recover from (and so it reloaded itself to restore service) ? Or is it possible that the PIX lost power ?
If a PIX loses power does it generate the crashinfo file ?
Piaras Walsh, Ireland
pix_device# show crashinfo
: Saved_Crash
Thread Name: Dispatch Unit (Old pc 0x001fe7c6 ebp 0x014d7b44)
Traceback:
0: 0010b2ce
1: 0010d6a5
2: 0010e281
3: 0066b772
4: 00580721
5: 00580755
6: 00580a9f
7: 00580ba9
8: 005deea9
9: 00651408
10: 006510de
11: 00553022
12: 001fe694
13: 001113d9
04-12-2006 12:49 PM
I have come across this crash trace back with a scenario involving H.225 traffic going through the PIX. Do you have a lot of H.225 traffic on this PIX? Also, if you do not need inspect h225, would you be able to disable it and see if the problem is seen again?.
But up to my knowledge, I would suggest you to consider upgrading to a interim release with bug-fixes and monitor.
04-20-2006 03:00 AM
I upgraded from 704 to 712. After the upgrade the PIX crashed every 10mins. Many 7.1 syslogs of these types wer observed:
%PIX-4-313005: No matching connection for ICMP
error message: icmp src Outside:internet_ip dst
Inside:inside_ip (type 3, code 3) on Outside interface.
Original IP payload: udp src 134.226.190.217/0 dst 88.105.72.1/1026.
%PIX-4-419002: Duplicate TCP SYN from
Inside_interface:inside_host/4239 to Outside_interface:internet_host/12775 with different
initial sequence number
The crashinfo traceback is:
Thread Name: Dispatch Unit (Old pc 0x00212b72 ebp 0x018499c4)
Traceback:
0: 0010b3ee
1: 0010d839
2: 0010e421
3: 00b18f75
4: 00b19771
5: 0068c2f0
6: 006934ce
7: 00692aa6
8: 0058c47e
9: 00212a08
10: 001116f9
vector 0x0000000e (page fault)
I had to re-install 704. Has anyone experienced similar problems ? Any help appreciated. Thanks.
05-16-2006 02:01 AM
I just had the same problem. After upgrade the both PIXes crashed in 1-2 min after rebooting every time. We're tried to fix bug when PIX crash after failing failover interface. It was necessary to downgrade back to 7.0(4). Now I think version 7.0(5) is the best choice in my case. Am I right?
Thanks!
05-16-2006 05:13 AM
I have been advised by TAC that the problem which causes the traceback shown above is resolved in 7.0.5 and 7.1.2.4. Alternatively I have been told that switching off HTTP inspection if running 7.1.2 will prevent the PIX from crashing. I am upgrading the production PIX this week. I will update this thread with the results.
