11-27-2003 03:19 AM - edited 03-09-2019 05:40 AM
We hav problems with connecting over VPN, when the client is located on another LAN and the users get "remote peer not resonding". But when using dial-up connection, they get through. What could be wrong? We are using Cisco VPN Client ver 4.0(rel), PIX Firewall version 6.2(1) and Pix Device Manager 2.0(1). I'm new to the PIX 501, so I need help!!! Here is my configuration(I haven't set this up. The company I'm working for have had someone to do it for them).
Building configuration...
: Saved
PIX Version 6.2(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxxxxx encrypted
hostname xxxx-PIX-501
domain-name xxxx.xxxxx
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
name xxxxxxxxxxxxxxxxxxxxx
access-list 100 permit ip 192.168.10.0 255.255.255.0 192.168.50.0 255.255.255.0
access-list outside_access_in permit icmp any any echo-reply
access-list inside_access_in permit ip 192.168.10.0 255.255.255.0 any
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside xxx.xxx.xxx.178 255.255.255.248
ip address inside 192.168.10.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool REMOTE-VPN-IP-POOL xxx.xxx.xxx.150-xxx.xxx.xxx.200
pdm location xxxx-xxxxx 255.255.255.255 inside
pdm location xxx.xxx.xxx.0 255.255.255.0 outside
pdm location xxx.xxx.xx.x 255.255.255.255 outside
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 100
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) xxx.xxx.xxx.xxx abcd-efghx netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa-server vpnauth protocol radius
aaa-server vpnauth (inside) host abcd-efghx ZAQ!2wsxpp timeout 10
aaa-server vpn protocol tacacs+
http server enable
http xxx.xxx.xx.x 255.255.255.255 outside
http 192.168.10.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt radius ignore-secret
no sysopt route dnat
crypto ipsec transform-set TRANSFORM-SET-ID-1 esp-des esp-md5-hmac
crypto dynamic-map DYNAMIC-ID 1 set transform-set TRANSFORM-SET-ID-1
crypto map CRYPTO-RULE 20 ipsec-isakmp dynamic DYNAMIC-ID
crypto map CRYPTO-RULE client configuration address initiate
crypto map CRYPTO-RULE client configuration address respond
crypto map CRYPTO-RULE client authentication vpnauth
crypto map CRYPTO-RULE interface outside
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup xxxx address-pool REMOTE-VPN-IP-POOL
vpngroup xxxx wins-server abcd-efgh1
vpngroup xxxx default-domain abcd.efghi
vpngroup xxxx idle-time 1800
vpngroup xxxx password ********
telnet 192.168.10.0 255.255.255.0 inside
telnet timeout 5
ssh xxx.xxx.xx.x 255.255.255.255 outside
ssh 192.168.10.0 255.255.255.0 inside
ssh timeout 60
vpnclient vpngroup xxxx password ********
vpnclient server xxx.xxx.xxx.xxx
vpnclient mode client-mode
terminal width 80
Cryptochecksum:xxxxxxxxxxxxxxxxxxxxxxxxxxxx
: end
[OK]
12-03-2003 08:04 AM
This is one of the common problems faced in such cases. please refer to the following document for the solution
Failed IKE Establishment
12-12-2003 04:35 AM
You have entered wrong access-list commands. The wild card bits works the other way around. Example : to permy all hosts in network 192.168.1.0 with subnet mask 255.255.255.0 the command is access-list 100 permit ip 192.168.10.0 0.0.0.255 192.168.50.0 0.0.0.255 .
At least this is one part of the problem. Let me know if this works.
