Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Help on WebVPN and OWA single sign on
I am wondering if anyone out there had succesfully implemented webvpn outlook web access single sign on (Basic only, no form base authentication) while OWA is using http only? I have tried and followed Cisco's document (http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00806ea271.shtml) to configure the device, but to no avail.
Here's my enviorment:
ASA5520 7.2(1), Cisco Secure ACS 4.0, Cisco Clean Access 4.0
Don't want to upgrade my ASA as yet to the higher version. Therefore because the bug listed below, won't be able to use OWA SSL in order to do form base auth.
CSCse76085 Bug Details
Headline
webpvn with OWA: file download with size>100KB stops
Product
pix-asa
Feature
OTHERS Components
Duplicate of
Severity
3 Severity help
Status
Resolved Status help
First Found-in Version
7.1(2.4)
First Fixed-in Version
7.3(0.41), 7.2(1.11), 7.1(2.18) Version help
Release Notes
Symptom:
When trying to download email attachements larger than 100KB, the file is not dowloaded correctly. This can be especially seen with images.
Conditions:
WebVPN is used in order to access OWA.
HTTPS is used for OWA.
Workaround:
Use HTTP instead of HTTPS.
Any help or idea to try to get wbvpn OWA SSO working is greatly appreciated.
Thank you.
1 REPLY
Silver
Re: Help on WebVPN and OWA single sign on
319
