Community Member
Help please for multiple IPSec termination on the PIX515
I have a question regards multiple IPSec termination on the PIX-515 firewall. "outside" configured for VPN client from ISP#1 and "vpn-chicago" for PIX-to-PIX from ISP#2.
the IPSec SA for "vpn-chicago" cannot encapsulate the interest traffic even increase the matching traffic for ACL 101. Any idea why cannot encap ?
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security10
nameif ethernet3 intf3 security20
nameif ethernet4 intf4 security20
nameif ethernet5 vpn-chicago security40
access-list 101 permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
ip address outside 66.163.23.33 255.255.255.240
ip address inside 192.168.100.32 255.255.255.0
ip address vpn-chicago 204.50.151.81 255.255.255.248
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
crypto ipsec transform-set cpi esp-3des esp-md5-hmac
crypto dynamic-map cpi-dyna 5 set transform-set cpi
crypto map cpi-map-chi 10 ipsec-isakmp
crypto map cpi-map-chi 10 match address 101
crypto map cpi-map-chi 10 set peer 66.166.107.82
crypto map cpi-map-chi 10 set transform-set cpi
crypto map cpi-map-chi interface vpn-chicago
crypto map cpi-map-dyn 20 ipsec-isakmp dynamic cpi-dyna
crypto map cpi-map-dyn client configuration address respond
crypto map cpi-map-dyn client authentication cpi-auth
crypto map cpi-map-dyn interface outside
isakmp enable outside
isakmp enable vpn-chicago
isakmp key ******** address 66.166.107.82 netmask 255.255.255.255
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup cpivpn address-pool vpn-pool
vpngroup cpivpn dns-server 192.168.100.5
vpngroup cpivpn wins-server 192.168.100.2
vpngroup cpivpn default-domain cpiplastics.com
vpngroup cpivpn idle-time 1800
vpngroup cpivpn password ********
pixfirewall# sh ipsec sa
interface: vpn-chicago
Crypto map tag: cpi-map-chi, local addr. 204.50.151.81
local ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (192.168.2.0/255.255.255.0/0/0)
current_peer: 66.166.107.82
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest 0
#pkts decaps: 708, #pkts decrypt: 708, #pkts verify 708
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 204.50.151.81, remote crypto endpt.: 66.166.107.82
path mtu 1500, ipsec overhead 56, media mtu 1500
current outbound spi: 438deb5e
inbound esp sas:
spi: 0x975c70ef(2539417839)
transform: esp-3des esp-md5-hmac ,
in use settings ={Tunnel, }
slot: 0, conn id: 1, crypto map: cpi-map-chi
sa timing: remaining key lifetime (k/sec): (4607919/25521)
IV size: 8 bytes
replay detection support: Y
inbound ah sas:
inbound pcp sas:
outbound esp sas:
spi: 0x438deb5e(1133374302)
slot: 0, conn id: 2, crypto map: cpi-map-chi
sa timing: remaining key lifetime (k/sec): (4608000/25514)
IV size: 8 bytes
outbound ah sas:
outbound pcp sas:
interface: outside
Crypto map tag: cpi-map-dyn, local addr. 66.163.23.33
Community Member
Re: Help please for multiple IPSec termination on the PIX515
Have you seen this?
http://www.cisco.com/warp/public/110/ipsec_tun_pass_data.html
It goes into the problems you can encounter when using the same access-list for no nat statements and pix2pix vpn tunnells
Hope that helps
Kev
Community Member
it was routing issue. the interest packet couldn't encrypt because there were no routing path for 192.168.2.0. working fine after add the following routing entry.
route vpn-chicago 192.168.2.0 255.255.255.0 206.186.248.49 1
89
