Community Member
help required in configuring telnet
We have two PIX 515E firewalls working in HA mode.
I wanted to configure telnet access to firewalls from outside interface.
PIX version is 6.3(5)
I kept PC outside to outside interfaces.
PIX outside IP is 10.10.200.3, inside IP is 10.10.202.5 corresponding virtual IPs are 10.10.200.2 and 10.10.202.7
I have tried following configurations:
pix(config)#telnet 0 0 inside
pix(config)#telnet 0 0 outside
pix(config)#telnet 10.10.200.0 255.255.255.0 outside
pix(config)#telnet 10.10.202.0 255.255.255.0 inside
pix(config)#telnet 10.10.200.200 255.255.255.255 outside
I am able to telnet from internal interface side using inside ip address.
But from outside test pc with IP 10.10.200.200 I am not able to telnet to PIX.
I enabled logging console 5.
when I tried to telnet to outside virtual IP it is not showing any traffic to firewall.
If I try to outside interface I am able to see the traffic like
packets received from source 10.10.200.200 to 10.10.200.3
any help in this configuration. I wanted to telnet firewall from test pc.
SKRAO
1 ACCEPTED SOLUTION
Bronze
Re: help required in configuring telnet
Hi Skrao,
PIX does not have the feature of allowing telnet from outside simply because it is insecure... the only way to have telnet from outside is by having an IPSec tunnel,
Alternatively, you can access the CLI from outside by SSH but you need to have something like the following commands:
FireWall# config t
FireWall(config)# ca zeroize rsa
FireWall(config)# ca generate rsa key 1024
FireWall(config)# ssh the_ssh_IP 255.255.255.255 outside
FireWall(config)# ca save all
You will use an SSH client like SecurCRT or PuTTy...
Don't forget to rate my post!
All the best
Osama
Bronze
Hi Skrao,
FireWall# config t
All the best
Osama
Silver
This is the 6.X command sequence, but if you are using 7.X use the commands below to accomplish this...
FireWall# config t
FireWall(config)# crypto key zeroize rsa noconfirm
FireWall(config)# crypto key generate rsa usage-keys noconfirm
Pls rate if this helps.
Cheers.
Jay
Community Member
You need to use SSH to connect to PIX from outside. telnet does not work from outside because of security reasons
114
