Help with ACL's
K newbie here.
I'm trying the deny everything approach. Thing is I'm not sure what all I should deny. My main goal is to block spyware such as Kazaa, Limewire and whatnot also porn dailers. I need to let through IM's though as we are an internet cafe.
I've read through the ACL doccies and I'm still a bit confused.
Any other security suggestions are welcomed.
I have 70 or so PC's using the 192.168.0.0 range and a second Fastethernet int using a public ip range (the web/mail server). Using a 2621 with serial int.
Tanks,
Here's the config so far:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname x
enable secret x
enable password 7 02040D4F080E
username x privilege 15 password x
ip subnet-zero
ip name-server 192.111.39.1
ip name-server 192.111.39.4
mta receive maximum-recipients 0
interface FastEthernet0/0
ip address 194.125.x.x 255.255.255.0
duplex auto
speed auto
no cdp enable
interface Serial0/0
description leased line to bob
bandwidth 128000
ip address 193.x.x.x 255.255.255.252
ip nat outside
no ip mroute-cache
shutdown
fair-queue
interface FastEthernet0/1
ip address 192.168.0.10 255.255.255.0
ip access-group 101 in
no ip proxy-arp
ip nat inside
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
no cdp enable
ip default-gateway 193.x.x.x
ip nat inside source list 102 interface Serial0/0 overload
ip classless
ip default-network 194.125.0.0
ip route 0.0.0.0 0.0.0.0 193.x.x.x
ip route 194.125.2.0 255.255.255.0 193.x.x.x
no ip http server
ip pim bidir-enable
access-list 101 deny igrp any host 255.255.255.255
access-list 101 permit ip any any
access-list 101 deny udp any any eq netbios-ns
access-list 101 deny udp any any eq netbios-dgm
access-list 102 permit ip any any
no call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
  • Other Security Subjects
Re: Help with ACL's
Hi Chris,
seems you have not yet implemented much alcs on Cisco systems. The entry "access-list 101 permit ip any any" must be the last in your acl because of permission of all ip packets all other entries would not be checked.
Build your access-list on the "inside" interface incomming in the way that you only permit wanted traffic and deny all the other.
In the second step build an access-list incomming on the "outside" interface and deny all private ip-addresses, broadcasts, multicasts etc. and permit all wanted traffic.
Also deny telnet and webserver on the outside interface.
Security is complex. Be aware of what you are doing.
Hope this helps you.
Best regards
Norbert
Re: Help with ACL's
Thanks Norbert. You are correct in your assumption that I haven't any experience with ACL's, hence the newbie comment. :)
Your response helped immensely. I have a few questions though (and they might seem a bit ridiculous to the more experienced).
When you say "inside" interface are you refering to the internal network interface (192.168.0.0) ? Is the "outside" interface the serial interface?
Does it matter what order the allowed traffic is listed other than before the deny all acl?
87
