Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
mis
Help with ASDM 5510
I am in desperate need of troubleshooting my ASDM 5510 as I am not able to use it as it is intended.
We route all traffic through an ISA 2004 server and use a 3rd party solution for filtering spam. We purchased the ASDM 5510 with the CSC SSM module and want to face out the 3rd party email scanner.
The issue I currently have is that email is not able to reach the Exchange 2003 server. For testing, I configured my .net domain to route email through the ASDM. Email does not reach the exchange server.
I am enclosing a diagram of my network layout and the configuration of my ASDM.
Ultimately, I would like to keep both routes open (ISA and ASDM) for Internet access while using the SSM to filter everything. You will notice that I have two subnets in place. The ASDM's Interface in the 192 subnet is currently unplugged as VPN clients could not access any network resources when both (172 and 192) interfaces were plugged in.
Any help will be appreciated!
1 REPLY
Re: Help with ASDM 5510
Your static statement and access-list entry for inbound smtp traffic looks correct to me. I would try running a capture on the inside interface of the ASA and make sure you see the smtp traffic leaving that interface destined for the exchange server.
1-'capture interface inside'
2-initiate inbound smtp traffic
3-'show capture '
4-'no capture ' when finished
You can also try enabling the ASA's logging buffer and see if there are any log entries being generated by SMTP traffic attempting to traverse the ASA.
1-'conf t'
2-'logging buffered info'
3-initiate inbound smtp traffic
4-'show log' or 'show log | grep
5- 'no logging buffered info' when finished
Hope this helps.
239
