Help with configuring a tunnel...
Hi! I want to configure a tunnel between a 871w (R1) and a 871 (R2).
R1 = 80.108.1.1, R2 = 80.109.2.2, these are public IPs.
R1 has no private network (yet), but R2 has a 10.0.0.40/29 on the inside. I like to establish a tunnel between R1 and R2 with the address of 10.0.0.64/30, and a dynamic routing protocol for learning all routes of the 10.x network. (dynamic, because at the end there will be 5 routers, with 10.x networks behind them...)
Currently, the config on R1 looks like:
interface Tunnel1014
ip unnumbered Loopback1014
tunnel source FastEthernet4
tunnel destination 80.109.2.2
tunnel sequence-datagrams
tunnel checksum
interface Loopback10
ip address 10.0.0.85 255.255.255.255
interface Loopback1014
ip address 10.0.0.65 255.255.255.252
router eigrp 1
network 10.0.0.64 0.0.0.3
network 10.0.0.85 0.0.0.0
no auto-summary
ip route 192.168.0.0 255.255.255.0 Vlan10 permanent
ip route 0.0.0.0 0.0.0.0 dhcp
access-list 101 permit gre host 80.109.2.2 host 80.108.1.1
interface FastEthernet4
ip access-group 101 in
(these should be all relevant config).
Of course, the other site is reverse... :-)
The tunnel is up, but I can't get a ping to 10.0.0.41 (which is fa0 in the remote router), I think this is because of the recursive routing...
Can somone give me a detailed config of how to get rid of this recursive routing problem? I tried "O'reilly Cisco Cookbook" recipe 12.3, but couldn't get it working...
Thanx in advance!
1 REPLY
Re: Help with configuring a tunnel...
First of all ;
You can change the ACL101 for permit esp any any and permit gre any any. Anyone can't pass gre traffic if you haven't create a VPN connection with it. If it's a security concern, you can had sonme security to you tunnel interface (ex.: Tunnel key).
But for troubleshooting you better remove your ACL.
You can add also the "tunnel mode gre" into your tunnel interface.
Does your IPSec SA is working fine ?
Does you receiving routing update ?
Which dynamic routing protocol are you using ?
Can you add a static route that simulate you dynamic routing proto to see if is a routing issue.
94
