Help with debug
I've got a pix firewall, and I'd like to monitor packets flowing from server1 to server2.
I've setup up the following debug list:
debug packet dmz2 src x.x.x.x dst y.y.y.y
The problem I have is that if I start debugging once I've entered this I see packets appear on my terminal. Once I log out and log back in the packets no longer appear in the terminal. If I do a "sh debug" I can see the debug rule is still there.
My question is where are is the debug information going?
Additional config that I have:
logging on
logging timestamp
logging console warnings
logging monitor debugging
logging buffered informational
logging trap informational
logging history debugging
logging host inside z.z.z.z
Thanks in advance
Dan
1 REPLY
Re: Help with debug
Hello Dan
According to your config,
debug info is logged to your terminal, only if your telnet session is active , so if your telnet or ssh session gets disconnected you will loose all the debuf info.
Once you reconnect to your pix via ssh or telnet you will have to do
conf t
term mon
and it will show you the debug info again.
Or you can change the logging trap to
logging trap debugging
and capture the info at host z.z.z.z
Hope this helps
87
