Community Member
Help with PIX515 and vpn web traffice not going through PIX for security
Hello.
I am terminating client sessions at my 515 Pix the problem I am running into is that when the clients establish a session they are not using the pix to route all traffice. For instance they go to yahoo they are using there ISP default gateway and I want it to go through the PIX can anyone help me here. I ahve tried the enable local lan option on the pcf file but to no avail.
David
1 REPLY
Silver
Re: Help with PIX515 and vpn web traffice not going through PIX
What kind of VPN sessions? IPSec with Cisco client? PPTP/LT2P? By default, the all traffic will traverse the tunnel unless split-tunneling is enabled. When using the PPTP/L2TP, you can't actually "force" this to happen as the clients will be able to control this. Using the Cisco VPN client, you can enforce this policies.
Give more info...
83
