Help with understanding config
I've inherited a firewall and I can see the following inside it. What I don't understand is why are there static maps in the config if the dmz is not using nat. Could someone please explain thei to me, the config is listed below.
global (outside) 1 xxx.xxx.17.3
global (dmz) 1 xxx.xxx.17.19
nat (inside) 0 access-list 124
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (dmz) 0 xxx.xxx.17.16 255.255.255.240 0 0
static (dmz,outside) tcp xxx.xxx.17.20 www xxx.xxx.17.20 www netmask 255.255.255.255 0 0
static (dmz,outside) tcp xxx.xxx.17.21 www xxx.xxx.17.21 www netmask 255.255.255.255 0 0
static (dmz,outside) tcp xxx.xxx.17.22 www xxx.xxx.17.22 www netmask 255.255.255.255 0 0
static (dmz,outside) tcp xxx.xxx.17.23 www xxx.xxx.17.23 www netmask 255.255.255.255 0 0
static (dmz,outside) tcp xxx.xxx.17.24 www xxx.xxx.17.24 www netmask 255.255.255.255 0 0
static (dmz,outside) tcp xxx.xxx.17.23 https xxx.xxx.17.23 https netmask 255.255.255.255 0 0
static (inside,dmz) 10.0.0.0 10.0.0.0 netmask 255.0.0.0 0 0
static (dmz,outside) xxx.xxx.17.25 xxx.xxx.17.25 netmask 255.255.255.255 0 0
static (dmz,outside) xxx.xxx.17.26 xxx.xxx.17.26 netmask 255.255.255.255 0 0
static (dmz,outside) xxx.xxx.17.28 xxx.xxx.17.28 netmask 255.255.255.255 0 0
static (dmz,outside) xxx.xxx.17.30 xxx.xxx.17.30 netmask 255.255.255.255 0 0
static (dmz,outside) xxx.xxx.17.27 xxx.xxx.17.27 netmask 255.255.255.255 0 0
Thanks in advance
Dan
Bronze
Re: Help with understanding config
hi dan,
as per the config , only "xxx.xxx.17.16 " is not getting NATed as it is NAT0. It doesn`t mean that whole DMZ is not getting NATed.
but other DMZ hosts are statically mapped to outside IP addresses to go out of the PIX.
hope this explains.
regards
aashish C
Thanks for the reply.
Just to elaborate on my question. What advantage is there to statically mapping the IP addresses to the same IP address. What would happen if I removed those mappings?
Thanks again
Dan
In fact the below instruction:
nat (dmz) 0 xxx.xxx.17.16 255.255.255.240 0 0 which covers any host xxx.xxx.17.17 - .30 covers all the below instructions already and they can be removed ..
In regards to your question .. I have seen this way to do configure "nat" which tries to make a host located on a higher security zone (dmz) reachable to a host on a lower security zone ( outside ). The best way to do it is using nat0 in combination with an access-list i.e
nat (lower secutity zone) 0 access-list outbound-no-nat
access-list outbound-no-nat permit ip any
Please rate it if you find it helps
I missed somehting on my previous post
In regards to your question .. I have seen this way to configure "nat" which tries to make a host located on a higher security zone (dmz) reachable to a host on a lower security zone ( outside ) USING ITS REAL IP ADDRESS. The best way to do it is using nat0 in combination with an access-list i.e
Well as per my understanding this is the communication pattern between DMZ (higher security level) and outside (lowest security level). First of all let me tell you PIX needs NAT rule to creat Xlate to get created, if you do not want to NAT any ip add so you use a trick to nat your ip to itself, as its being happen in "static" command.
Secondly if you use nat (DMZ to outside) so you can only initiate session from DMZ not from outside.
Here STATIC command comes with the facility to make permanent Xlate like here from (DMZ to outside) that could be accessed from outside (if permit ACL is available on outside interface).
I think this can help you out that
* why use translate in the same ip
* why use multiple STATIC instead of single NAT Statment
123
