Help with VPN!
I have a Cisco 1720 router that has the only public IP on the network. I have just put a PIX 506 firewall behind it on a private IP.
The Cisco 1720 is performing NAT on all packets. The PIX is not doing NAT.
Because I cant address my pix on a public IP I am pointing my VPN client at the routers Public IP, but I dont think that it is passing on the IPSEC packets! I am using the PIX to create the VPN tunnel and authenticate the remote VPN clients.
I am using Cisco VPN client ver 3.5 and 3DES.
What do I need to allow through the router? Or is it possible to do what I am trying to do!?
Re: Help with VPN!
This is a sample config that you can follow to base your config for what you want to do :
http://www.cisco.com/warp/public/471/ios_pat_ipsec_tunnel.html .
Please taken note of the version of router that support this static esp and static isakmp feature.
Re: Help with VPN!
Thanks for the link, it mostly makes sense! I will definatly have to update my router IOS ;-)
Dave
98
