Community Member
HELP !!!!
I have managed to delete the standard startup file for my 1720 router. Could anyone send me one ?
Community Member
Re: HELP !!!!
What standard startup file? Your basic configuration? Here’s a link that will help you start over: http://www.cisco.com/pcgi-bin/Support/PSP/psp_view.pl?p=Hardware:1700
Community Member
Re: HELP !!!!
Hi Steve,
If you erased your startup config and if your router
has not been power cycled, then you can just use
the 'write mem' command ... the running config will
be saved in the non volatile ram.
Philippe
103
