Community Member
How can I get IPSEC to work dynamically on a hub and spoke network
I have 112 Cisco 2610 router and two Cisco 7206 router.
All the Cisco 2610 connect to the two 7206 routers through a frame relay.
All the Cisco 2610 are also required to communicate to each other via the Cisco 7206
I am required to encrypt every data traffic going through the frame relay.
And I cannot get the configuration below to work dynamically.
But when I remove all “crypto dynamic-map …..” and also replace this “crypto isakmp key 30364050 address 0.0.0.0 “ with “crypto isakmp key 30364050 address 130.3.6.2 or a specific interface address of the remote peer it will work. See below the error that I get
Please help me. I want dynamic-map design to work because of the need for HUB to SPOKE and SPOKE-to-SPOKE communication. It will too much work to encrypt all the router manually.
Cisco 7206 router
crypto isakmp enable
crypto isakmp identity address
crypto isakmp policy 1
encryption des
hash md5
authentication pre-share
group 1
lifetime 86400
crypto ipsec transform-set dataset ah-md5-hmac esp-des esp-md5-hmac
crypto map its2data 1 ipsec-isakmp
match address 116
set peer 130.3.6.2
set transform-set dataset
crypto dynamic-map its2dyn 10
match address 116
crypto map its2data 2 ipsec-isakmp dynamic its2dyn
access-list 116 permit ip 130.1.2.0 0.0.0.255 130.0.0.0 0.255.255.255
interface s3/3.52
crypto map its2data
***********************************************8****
Cisco 2610 router
encryption des
hash md5
group 1
lifetime 86400
match address 116
set peer 130.3.6.1
match address 116
interface s0/0.30
crypto map its2data
******* error message *******
ov 8 13:35:46.934 EST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSE
C packet.
(ip) dest_addr= 130.1.2.1, src_addr= 130.1.6.16, prot= 1
Nov 8 13:36:46.934 EST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSE
C packet.
Nov 8 13:37:46.938 EST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSE
C packet.
Nov 8 13:38:46.938 EST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSE
C packet.
Nov 8 13:39:46.938 EST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSE
C packet.
Nov 8 13:40:46.938 EST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSE
C packet.
Nov 8 13:41:46.938 EST: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSE
C packet.
Re: How can I get IPSEC to work dynamically on a hub and spoke n
Here is a sample config that should work:
hash md5
crypto isakmp key cisco123 address 0.0.0.0
crypto ipsec transform-set hub esp-des esp-md5-hmac
crypto dynamic-map spoke 10
set transform-set hub
match address 116
crypto map test 10 ipsec-isakmp dynamic spoke
(don't place anything under this crypto map, place info under dynamic map)
interface Serial0
crypto map test
access-list 116 permit ip 130.0.0.0 0.255.255.255 130.0.0.0 0.255.255.255
(make them general at first at see if works, if does then make it specific and see if works)
Also take a look at this link (if want to use Tunnel End-point Discovery): http://www.cisco.com/warp/public/707/tedpreshare.html
Hope it helps.
Steve
Community Member
Dear Steve,
I have tried you sample configuration exactly as you wrote it.
and also used different access-list and none worked.
I also tried the Configuring IPSec Tunnel End-Point Discovery sample and it did not work
I noticed that the ios for the Configuring IPSec Tunnel End-Point Discovery sample is 12.07 and the ios in my routers are 12.09. Could that be the problem. I can not figure out any other problem. Because I tried adding discover on my "crypto map test 10 ipsec-isakmp dynamic spoke " as the configuration showed but was not able.
Thanks for any more help
Godswill
162
