Community Member
how configure FWSW 's transparent Mode?
thank you
Silver
Re: how configure FWSW 's transparent Mode?
Not sure if you are looking for any specific clarifications on the trasnparent mode, but as far as FWSM concerns, configuration for FWSM is the same, regardless of which mode you use. Please, refer to the following link -
http://www.cisco.com/en/US/products/hw/switches/ps708/products_installation_and_configuration_guide_chapter09186a0080159cac.html#1066911
Mynul
Community Member
thank you very much.
but i know the netscreen ' trasnpaarent mode is very easy,you set a manager ip only.
i dont' know the FWSM as same as the netscreen.
104
