How do I clear a stuck route from an ASA 5515-x?
I have a very unusual situation. I have an ASA 5515-x running Cisco Adaptive Security Appliance Software Version 9.1(4)
I have a stuck static route that I cannot remove from the device. I have tried clear configure route BGPDMZ:
cerberus-01(config)# clear configure route BGPDMZ
cerberus-01(config)# exit
cerberus-01# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is not set
S    70.39.130.0 255.255.255.128 [1/0] via 162.222.65.1, BGPDMZ
S    173.205.112.0 255.255.255.128 [1/0] via 162.222.65.1, BGPDMZ
S    192.168.200.0 255.255.255.0 [1/0] via 162.222.65.1, BGPDMZ
C    162.222.64.0 255.255.255.0 is directly connected, Inside64
C    162.222.65.0 255.255.255.224 is directly connected, BGPDMZ
C    162.222.66.0 255.255.255.0 is directly connected, Inside66
D    10.10.10.0 255.255.255.248 [90/28416] via 10.10.11.1, 0:37:56, Intra-colo
C    10.10.11.0 255.255.255.252 is directly connected, Intra-colo
S    192.168.100.0 255.255.255.0 [1/0] via 162.222.65.1, BGPDMZ
cerberus-01#
It lives?
I tried no route....
I tried no route and then D/C power for 5 mins...
This route no longer exists in the conf yet it will not delete from routing table. Can anyone help me or do I need an exorcist?
Steve
Everyone's tags (1)
HiCan you share me show
Can you share me show running route output and show version output from your ASA
Sandy
Hall of Fame Super Silver
Do you perhaps have reverse
Do you perhaps have reverse-route injection configured on a VPN? That will populate the routing table in the manner that you are seeing.
95
