How do I confirm IPSEC is working between two routers?
We are in the process of implementing IPSEC on our premise routers; what is the best way of varyfing that IPSEC is workign proparly? What are the best IOS commands to varify IPSEC is working? If IPSEC is working properly, can i still ping routers in the middle, that don't have IPSEC installed? What visible commands/actions will I be able to observe once I have IPSEC configured properly?
Also, before be deploy IPSEC on the operational routers, what tests can we use in-house to varify connectivity will be the same as in the operational environemt?
So far we plan to test IPSEC between routers connected in a LAN environment, and connect together through DTE-DCE to simulate a WAN environemt. Any other recommendations on how to test?
thnxs for any input..
Francino
Re: How do I confirm IPSEC is working between two routers?
Hi Francino,
You can use the following commands to verify that IPSec is running/working between two end devices:
show crypto ipsec sa
show crypto engine connection active
You will see if the IPSec SA's have been established and if the traffic is getting encrypted/decrypted at the end points.
Additionally, you should be able to ping any devices in the middle which have routable IP addresses even if they are not running any IPSec on them.
Hope this helps,
Aamir Waheed,
Cisco Systems, Inc.
CCIE#8933
Thanks Aamir!
331
