how do i enable webvpn on the ASA outside interface
Hi Forum,
how do i remove the ASDM administrative session on the outside interface, so that i can enable the webvpn?
thanks,
paul
1 ACCEPTED SOLUTION
Gold
Re: how do i enable webvpn on the ASA outside interface
ASDM is turned on by command http server enable so if you need disable this use commad no http server enable
Check this link for more details
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a008054d863.html#wp1047288
M.
Hope that helps, rate if it does
Gold
M.
Thanks M.Sir, it resolves my problem. thanks.
225
