Community Member
How do I erase the Running Config on a PIX-515E with OS 7.1(1)
I am totally new to PIXes and need to erase/delete the running config from this Firewall with OS 7.1(1)
I thought that "clear configure all" would do the trick but the command does not even appear listed when I do a "?" on the command prompt....
capture Capture inbound and outbound packets on one or more
interfaces
cd Change current directory
clear Reset functions
client-update Execute client updates on all or specific tunnel-groups
clock Manage the system clock
configure Configure using various methods
copy Copy from one file to another
crashinfo Crash information
I also tried on configuration terminal but the command is not listed there either....
ca Certification authority
checkheaps Configure checkheap verification intervals
class-map Configure MPF Class Map
clear Clear
client-update Configure and change client update parameters
clock Configure time-of-day clock
command-alias Create command alias
console Serial console functions
crashinfo Enable/Disable writing crashinfo to flash
crypto Configure IPSec, ISAKMP, Certification authority
Any ideas how can I get around this????
Also, on a firewal, is ther a command that has the same function that "Control+Z" has on a Cisco router/switch???
Thank you for any help!!!!
1 REPLY
Re: How do I erase the Running Config on a PIX-515E with OS 7.1(
hi
do u want a fresh PIX with factory default config ?
if thts the case try executing write erase command and reboot without saving the current running config..
regds
1563
