Community Member
How do i establish tunnel between Contivity 1100
Hi ,
I have a VPN Concentrator & Contivity Box, i want to establish tunnel between them. Where can i find a Document on this ?
Please help
1 REPLY
Bronze
Re: How do i establish tunnel between Contivity 1100
Use the following URL to configure the concentrator, the only problem you might encounter is the IKE lifetime problem. Match the IKE lifetime value that is set in contivity.
269
