How do I issue the class-map command
I have a cisco pix 515e, os version 6.2(2). I'd like to know how to issue the class-map command.
When I list the commands available to me in "configure terminal" mode there isn't a class-map function listed. Can anyone help me with this please.
Dan
1 REPLY
Purple
Re: How do I issue the class-map command
Hi Dan,
That command is only available starting from version 7.0 of the software. You need to upgrade to be able to use it.
Hope that helps - pls rate the post if it does.
Paresh
91
