How do I mount local DVD/CDROM in ISE / ADE enviroment
Hi All,
I have notice that config repository url -> cdrom: options..
but when I check show ver at ISE, did not find cd rom.
How do i mount CD rom from ADE env
John
1 REPLY
Re: How do I mount local DVD/CDROM in ISE / ADE enviroment
Hi John,
For backup and restore operations, you cannot choose the CDROM, HTTP, or HTTPS options because these are read-only repositories.
1209
