How do I open for port 7205 from DMZ to the inside
I have a pix 515
How do I open for port 7205 from DMZ server(192.168.100.2) to the inside server (192.168.0.248)
PIX Version 6.0(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 DMZ security50
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list nonat permit ip 192.168.0.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list nonat permit ip 192.168.0.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list nonat permit ip 192.168.200.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list nonat permit ip 192.168.200.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list fromoutside permit tcp any host 195.215.212.76 eq www
access-list fromoutside permit tcp any host 195.215.212.77 eq smtp
access-list fromoutside permit icmp any any echo
access-list fromoutside permit icmp any any echo-reply
access-list fromoutside permit icmp any any unreachable
access-list fromoutside permit icmp any any source-quench
access-list fromoutside permit tcp any host 195.215.212.78 eq smtp
pager lines 24
logging on
logging trap informational
logging history informational
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
mtu outside 1500
mtu inside 1500
mtu DMZ 1500
ip address outside 195.215.212.74 255.255.255.248
ip address inside 192.168.0.254 255.255.255.0
ip address DMZ 192.168.100.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool ippool 192.168.2.1-192.168.2.254
pdm history enable
arp timeout 14400
global (outside) 1 195.215.212.75
nat (inside) 0 access-list nonat
nat (inside) 1 192.168.0.0 255.255.255.0 0 0
nat (inside) 1 192.168.200.0 255.255.255.0 0 0
static (DMZ,outside) 195.215.212.76 192.168.100.1 netmask 255.255.255.255 0 0
static (inside,outside) 195.215.212.77 192.168.0.6 netmask 255.255.255.255 0 0
static (inside,outside) 195.215.212.78 192.168.200.245 netmask 255.255.255.255 0 0
access-group fromoutside in interface outside
route outside 0.0.0.0 0.0.0.0 195.215.212.73 1
route inside 192.168.200.0 255.255.255.0 192.168.0.200 1
timeout xlate 1:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
---snip---
Best Regards
Ole Kyrstein
1 REPLY
Gold
Re: How do I open for port 7205 from DMZ to the inside
Hi Ole,
you will require a static and access-list, please read the following URL for guide. The guide is for pix 6.1
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_61/cmd_ref/s.htm#1026694
and this URL might be of help too:
http://www.cisco.com/warp/public/707/28.html
Remember, if you modify static,ACL's makesure to save with command 'write memory' and also clear translations with command 'clear xlate' to make the new rules active.
Thanks- Jay
176
