06-26-2002 09:33 AM - edited 02-20-2020 10:07 PM
We have an oracle server off the PIX's DMZ interface (E2) w/ an IP address of 10.10.10.10 /24. The internal users are on the PIX's INSIDE interface (E1) and their subnet is 192.168.1.0 /24. Users on this internal subnet need to access the web; therefore, they are NAT'd out the OUTSIDE interface (E0). However, for these same internal users to access the oracle server (10.10.10.10) on TCP port 1521, they cannot be NAT'd to connect. How do we allow NAT'ing to work for internet access and at the same time prevent NAT'ing to occur when accessing the oracle server on the DMZ?
Here is what I did....
access-list INSIDE permit tcp any any eq 1521
access-group INSIDE in interface inside
nat (inside) 100 0 0
nat (dmz) 100 0 0
global (outside) 100 172.16.1.1
global (dmz) 100 10.10.10.100-10.10.10.200
access-list NoNAT permit ip any host 10.10.10.10
nat (inside) 0 access-list NoNAT
How come this doesn't solve the problem?
We are running Cisco Secure PIX version 5.2(3)
06-26-2002 09:33 AM
try selecting access-lists with subnets.
Example:
clear nat
access-list 101 permit 192.168.1.0 255.255.255.0 host 10.10.10.10
nat (inside) 100 192.168.1.0 255.255.255.0
nat (inside) 0 access-list 101
if it doesn't work, remove the last global (dmz) statement
otherwise, try upgrading to PIX OS 5.3.2 or to PIX OS 6.1.1
it should work, it is a well-known configuration.
06-26-2002 12:05 PM
06-26-2002 12:06 PM
06-26-2002 12:08 PM
Hi mate,
I think I know where u'r problem may be,,,and if you can drop me a copy of the config ( ofcourse remove all the sensitive information), and a contact number I will call you back,,,
e-mail : moh_alam@hotmail.com
Moh
