How do IPsec Peers know remote peer is dead?
How do IPsec Peers know remote peer is dead? Now,I need config IPSec between Cisco router and other's router in a case,but cisco router can't know remote peer is dead,so IPsec conversation can't switch over another path when primary path is down
How can cisco ipsec protocol detect the dead of other Vendor's ipsec implement?
  • Other Security Subjects
1 ACCEPTED SOLUTION
Silver
Re: How do IPsec Peers know remote peer is dead?
They don't. There is nothing in the ipsec specification to make this work. Cisco has a proprietary method that they have added as an optional setting to many of their devices, but since there is a non cisco device in the mix, you are out of luck.
Your only option is probably to lower to lifetimes of SAs, so that they are renegotiated more frequently. This will likely increase overhead though
Silver
ezy
i don´t know your detailed network, but you can try some kind off GRE tunnels with a routing protocol. Then you have the capabiltiy to switch from one path to another.
Erich
100
