How many 3rd Party Certs required for ASA HA configuration
I want to install a VeriSign certificate on my active-standby HA pair. Do I need one cert or two?
Paul
1 REPLY
Silver
Re: How many 3rd Party Certs required for ASA HA configuration
The certificate that you get you will need to install in both firewalls. You will need one certificate. You will not need two seperate certificate as long as the hostname on both firewalls is the same.
Try this link
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_7_1/conf_gd/certs.htm
222
