How Many ACL Entry
Hello ~
I would like to know , The Cisco PIX 535 can support how many acl rule ?
Re: How Many ACL Entry
The limit on the number of ACLs on the 535 is more a function of the maximum configuration size, which is 2 MB. What that means is that the ACL limit would be determined by the maximum configuration size minus the size of the rest of the configuration.
If performance of a large ACL is an issue, you may want to consider Turbo ACL's that was added to later PIX code.
Hope this helps.
Scott
Silver
As mentioned, the config size is the limiting factor. Turbo ACls will let the Pix process them faster. [access-list compiled] Be careful about making changes during heavy loads as the pix recompiles the ACL everytime there is a change.
To keep the config size as small as possible for max ACE entries, use the object-groups whenever possible. Adding multiple hosts to an object-group has a smaller footprint than the same number of ACEs. However, this is only true if you're going to make several entries in the object-group.
148
