How many IPSEC Tunnels ?
I currently have Pix 525 in HA environment. I m currenlty running 22 site to site IPSEC Tunnels, Can some one please suggest, I currently I have unlimited licenses of the IKE Peers, but i want to make sure so that i dont overkill the PIX before i add any new tunnels.,
Here is the sho ver of my PIX
With 6.2.2 and Hardware: PIX-525, 256 MB RAM, CPU Pentium III 600 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Gold
Re: How many IPSEC Tunnels ?
i guess 525 can handle much much more than that.
according to cisco doc:
PERFORMANCE SUMMARY
Cleartext throughput: Up to 330 Mbps
Concurrent connections: 280,000
168-bit 3DES IPSec VPN throughput: Up to 145 Mbps with VAC+ or 72 Mbps with VAC
128-bit AES IPSec VPN throughput: Up to 135 Mbps with VAC+
256-bit AES IPSec VPN throughput: Up to 135 Mbps with VAC+
Simultaneous VPN tunnels: 2000
Thank you
Gold
it's good to learn that the info provided is helpful.
according to cisco:
Why should I rate posts?
If you see a post that you think deserves recognition, please take a moment to rate it.
You'll be helping yourself and others to quickly identify useful content -- as determined by members. And you'll be ensuring that people who generously share their expertise are properly acknowledged. As posts are rated, the value of those ratings are accumulated as "points" and summarized on the Member Profile page and on each member's Preferences page.
260
