Community Member
How many simultaneous VPN connecitons...
How many simultaneous VPN connections can you have utilizing the ASA-5510? Will using a NAC affect this number? Thanks in advance.
1 ACCEPTED SOLUTION
Re: How many simultaneous VPN connecitons...
Bill,
The below data sheet for the ASA has the information that you are looking for.
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/product_data_sheet0900aecd802930c5.html
IPsec VPN Peers - 250
SSL VPN Peer License Levels* - 10, 25, 50, 100, or 250
Also, it is my understanding that using NAC should not affect the above numbers.
Arul
*Pls rate if it helps*
1 REPLY
Bill,
Arul
120
