11-18-2002 05:38 PM - edited 03-09-2019 01:07 AM
We are using PIX-525 and have three interfaces: Outside, Inside and DMZ1.
Does anybody know the command to allow all IP traffic from dmz1 to inside interface?
Simon
11-18-2002 06:54 PM
To allow traffic from a lower security interface (dmz1) to a higher (inside), you need a static and an access-list. If you just want all traffic to flow between these interfaces as though the PIX was a router and not a firewall, then you need to create static NAT entries for every host on the inside so that they appear on the dmz1 interface, and then simply permit all IP traffic with an access-list.
Let's say your inside interface is on the 10.1.1.0/24 network, and your dmz1 interface is on the 172.16.1.0/24 network. You'd do:
static (inside,dmz1) 10.1.1.0 10.1.1.0 netmask 255.255.255.0
access-list 100 permit ip 172.16.1.0 255.255.255.0 10.1.1.0 255.255.255.0
access-group 100 in interface dmz1
Of course this takes away the security of having a DMZ in the first place.
11-19-2002 09:23 AM
Thank you for your answer.
Are the above commands taking away the security from the outside to the
inside and from the outside to the dmz1? We need the security stay for
"outside to inside" and "outside to dmz1" and security can be taken
away between "dmz1 and inside".
In addition to your commands above, can I add the following command to
do the same function but from higher security (inside) interface to a
lower security interface (dmz1)?
static (dmz1, inside) 172.16.1.0 172.16.1.0 netmask 255.255.255.0
access-list 101 permit ip 10.1.1.0 255.255.255.0 172.16.1.0 255.255.255.0
access-group 101 in interface inside
Same question again:
Are the above command taking away the security from the outside to the
away between "inside and dmz1".
Thank you very much for your help again.
Simon
