How to allow outside user to browse the inside web site??
m.hossein
Hi all,
I have PIX firewall with 6.0(1) and I am running my mail server behind it and it works find till now...
these days I need to run a web server "apatche" behind it..
I tried to configure it to allow the oursiders to access the inside web bage by usning the following commands:
static (inside,outside) xx.xx.60.21 10.0.0.20 netmask 255.255.255.255 0 0
conduit permit tcp host xx.xx.60.21 eq www any
I failed to run this web sites installed on the apatche server...
Please help me to fix this issue ASAP
Thanx in advance
magdy
jmia
Level 7
Level 7
Read the following URL document - this might guide you to your answer:
http://www.cisco.com/warp/public/707/28.html#trust
Hope this helps,
Jay
vkhanduri
1.Make sure that you have a route back to 10.0.0.0 network to your inside network if your inside netowrk is on some other networkmin the PIX.
2. Default route ofcourse within your secured network should be pointing towards PIX and PIX in turn pointing to your perimeter router out ot internet.
Vikas
