How to apply mutiple rules/filters to an Lan2Lan tunnel on VPN3030
Like the title said, i have this existing LAN to LAN tunnel, and i would like to put more restriction on it. there is already a LAN to LAN rules created as default, when you create the tunnel, but how can we restrict it even more, like only allow pop, smtp and Http?
any suggestion would be really appreciate.
thanks in advance
1 REPLY
Re: How to apply mutiple rules/filters to an Lan2Lan tunnel on V
You can't apply a filter to a LAN-to-LAN tunnel group (well, you can, but it doesn't do anything). This was filed as a bug (CSCdu56232) way back but became an enhancement request and was finally put into release 3.6 on the concentrator code (although I must admit I haven't tested it).
You should be able to simply create a filter and rules and then go under the Group section, you'll see a group created for the LAN-to-LAN tunnel you created. Modify that and add the Filter under the General tab.
Let me know if it works or not, as I said I haven't tested it (you don't mind being as guinea pig, do you?).
183
