11-10-2006 08:12 AM - edited 03-09-2019 04:51 PM
I'm trying to find out where in the 3000 concentrator I can turn on auditing of successful logins to send to my syslog server (MARS) so I can run a report from last month to see who is logging in remotely. Thanks in advance!
11-13-2006 01:27 PM
Hi Paul
You dont mention what authentication method you are using or type of vpn session (IPSEC or SSL)
I`ve not had chance to test this, but looking at the Events for the Concentrator...
VPN Concentrator
Configuration>System>Events>General
Select the Events to Syslog Field, Usually 1-5 for MARS.
In MARS
Event ID: 7002776
Event Type Details: Cisco VPN Authentication successful
This event indicates that an authentication request has been successful. The event text will point to the server and user ID.
Report: COBIT DS5.2: Authentication and Access
Activity: Remote Access Login - Top User (Total View)
Looking at the event types for this report...
Info/SuccessfulLogin/AAA, you may need to be using Cisco ACS for Authentication.
11-14-2006 08:29 AM
Hi Chris, I'm using IPSEC with group names (may have a group called IT that has 3 users in that group). I have it setup the way you describe, but I don't see anything in MARS. In MARS I run the report "This report ranks users by remote access logins (PPP, L2TP, PPTP, IPSec)." and the report is blank (no users or groups). I double checked to make sure the syslog server is pointed to the MARS IP address. Thanks
11-22-2006 01:53 AM
Hi Paul
If you run a query, on RAW Event, from just the Concentrator (over the last hour or so, or real-time) do you see any events coming in?
Chris
ciscomars.blogspot.com
